Well, chalk this up as a learning experience. Side exit exhaust dont do it!
Discussion in 'Challenger R/T Engine & Performance Modifications' started by BBBAD345, May 16, 2020.
  1. BBBAD345
    BBBAD345 Member
    Illinois
    Got the new side exit exhaust installed. Got to take it off though, it's too loud and drags on the ground every so often. It's a long video. It's a cold start to a warm 650 idle. It starts to warm up at 3 minutes and completely idles down at 5 minutes. The video is almost 6 minutes long.
  2. B5blueRT
    The cam sounds good, nice and lumpy. Did you record this with the car in a garage? It would be nice to hear it outside, standing outside the car.
  3. 2017 Redline HC
    I second that!
  4. BBBAD345
    BBBAD345 Member
    Illinois
    Yes was in garage. I'll be swapping the exhaust this week for something else and will do a sound clip outside before I remove this one.
    The problem I have been having is that last summer I had a Ford 9-inch installed from DSS. The exhaust system was only about an eighth of an inch away from the output bearings on the pumpkin. This caused the lube to overheat and boil and it also cooked the inner CV joints. The CV joint and Axle Repair cost me almost six hundred bucks. Kind of pissed me off since it was a brand new rear end. And I had to foot the bill for the repairs because the guy that installed the rear end for me didn't give two thoughts about heat soak from the pipes ruining everything. Not too happy about that. But it is what it is. So I have to build another custom exhaust with mufflers and spouts under the car. Then next year I will have some custom tail pipes made to replace the spouts. For now I just want to get the car rolling again. So if the pipes have to dump right after the muffler under the rear seat then so be it.
    Cam is 227/235 116LSA 112ICL .619/.612
    Forged CPCarrillo 9.5-1 pistons (+0.020), Molnar H-Beam rods, 6.1L crank.
    ProCharger P1SC-1, 12.5 psi.
    Tim Barth tuned, 746whp.
  5. BBBAD345
    BBBAD345 Member
    Illinois
    I did a vid outside garage after a warm up cruize. When I got home I saw that my new x pipe was on the front porch. So Wednesday I will raise the car up in the garage and start installing my new system with my mufflers. I have Flowmaster FX stainless Mufflers to go on it.
  6. B5blueRT
    It's a shame you can't find some thin glasspacks or chambered pipes to replace a small portion of the existing straight pipes. I know, ground clearance could be an issue.
    Good luck, nice car! Keep us up to date.
  7. BBBAD345
    BBBAD345 Member
    Illinois
    I basically did it just to do it. Always wanted to try it. If it worked out cool, if not oh well only out a few bucks and I got to say I did it. I'm going to remove the side exit exhaust and hang it on the wall in my garage bar as a trophy. :D
    Next year I've got a guy in the Chicago suburbs who does custom exhaust who will install tail pipes in place of the spouts.
    Dennis Creese likes this.
  8. BBBAD345
    BBBAD345 Member
    Illinois
    No new x pipe and mufflers with spouts have been installed. The car is very quiet now compared to how I have been running it over the last 6 years. But it will become one hell of a sleeper. Email tuning starts tomorrow.
    B5blueRT likes this.
  9. BBBAD345
    BBBAD345 Member
    Illinois
    Email tuning has been coming along quite nicely. It is finally running well. It will be perfect soon. The new exhaust and Xpipe (flowmaster Xforce mufflers installed with spouts) flow so well compared to the factory H pipe and straight pipes that my boost dropped almost 2 points at 6K from 12.0 to about 10.0 psi. My tune guy was able to add 3* timing and wake it the heck up. It runs HARD. And their is still more tuning to go.
    I found a road to log on buy my house. I took it out there and started to log. After I was done logging I proceeded to upload to an email and send it to my tune guy. While pulled over in the middle of nowhere, a guy in a Jeep pulled up to see if I was ok. I explained what was going on and he was all like "dude, no one out here will care. In fact I live right over there, how bout you follow me home and give me a ride in that thing". So I did... He loved it.
