Tire sidewalls turn brown because of a reaction called tire blooming. This occurs when antiozonant chemicals in the tire’s rubber react with oxygen and UV light. While this process is natural, it can be unsightly. In this article, we’ll explore “why tire sidewalls turn brown and how to prevent it” effectively, sharing tips and insights on this common issue.
Understanding Tire Blooming
Tire blooming is a chemical reaction that results in the brown discoloration of your tires’ sidewalls. Oils and other substances released from the tire cause this discoloration. This phenomenon occurs due to the antiozonant compounds in the rubber, which are designed to protect the tire from the damaging effects of ozone and UV rays. If you’ve encountered tire blooming, you’re witnessing this natural process, which is not the tire itself but a reaction happening on its surface.
Tires bloom because antiozonant pushes its way to the outer edge of the rubber casing with time. As the element comes into contact with oxygen, it leaves a brown residue on the surface of the tire. Antiozonant is organic and helps tires last longer as it slows deterioration due to oxidation. This makes it possible to manufacture long-lasting, high-mileage tires. The rubber structure is designed to allow the element to move forward to the surface, thus continuously providing the material with its benefits. As a result, the tire remains pliable and UV/oxygen-resistant for a longer time.
While mold releases or silicone-based products don’t cause tire blooming, they can exacerbate the problem by trapping antiozonants on the tire surface.
Despite not affecting tire performance, tire blooming leaves a brownish hue that many car owners find unattractive. By adopting regular maintenance and proper care, the effects of tire blooming can be mitigated, keeping your tires clean and visually appealing.
Causes of Tire Browning
Tires bloom due to the interaction of their compound components with UV rays. Exposure to UV light can cause the rubber in tires to break down, leading to browning. Additionally, oxygen and ozone in the atmosphere can degrade tire rubber, contributing to the brown residue that forms on the tire surface.
Organic compounds known as antiozonants are added to rubber materials to slow down deterioration caused by environmental exposure. They prevent the surface of the material from oxidizing and keep the material pliable. However, these antiozonants also react under the influence of UV light, oxygen, and heat, leading to tire browning.
While this process contributes to the production of durable, high-mileage brown tires, it also causes the tire sidewalls to turn brown over time.
Antiozonant Used to Avoid Browning
Tire manufacturers use specific chemicals, called antiozonants, to prevent tire sidewalls from turning brown. The most commonly used antiozonant in tire manufacturing is 1.3-Dimethylbutyl-N′-phenyl-p-phenylenediamine (6PPD). This compound migrates to the tire surface, where it reacts with ozone and prevents the rubber from oxidizing and cracking, thereby extending the tire’s life and maintaining its appearance.
6PPD continuously provides protection as long as it remains within the tire compound. Its migration through the rubber to the surface ensures ongoing protection against ozone exposure. In addition to 6PPD, manufacturers may use other materials like waxes to provide both short-term and long-term ozone protection, enhancing the overall durability and appearance of the tires.
Impact of Mold
Mold releases used in tire manufacture don’t cause tire sidewalls to turn brown directly. However, they contribute to the issue by keeping the antiozonant on the tire’s surface. The closer it is to the outer edge of the tire structure, the more the oxidation process will cause it to leave a brown residue.
Mold releases are non-stick lubricants applied in tire molds to help release the tires smoothly. Some of this lubricant often remains on the tire, which may contribute to blooming after just a few weeks of driving.
Silicone as a Contributor
Tires do not bloom because of silicone-based tire dressings. Silicone is sticky, so it may allow dirt and dust to hold on to the surface of the tire as you drive, which makes tire sidewalls turn brown. The tire becomes dirty but doesn’t bloom. In this case, you can remove the color with a simple cleaning using a brush and some water. Or, remove silicone-based dressings with special degreasers and scrubbing.
Brake Dust Impact
Brake dust, composed of metal and rubber particles, can cause tires to turn brown. These metallic particles can stick to the tire surface, further attracting antiozonants to the surface, where they react and cause blooming.
Brake dust acts as an abrasive, wearing down the tire surface and making it more susceptible to blooming. It can create a layer on the tire surface that traps moisture, leading to increased tire blooming. Regularly scrubbing tires to remove brake dust can help prevent this acceleration of the blooming process.
Tire sidewalls from turning brown: preventative measures
Maintaining tire sidewall color involves regular cleaning, applying quality tire dressings, and avoiding silicone-based products. Thoroughly cleaning and protecting the tires are essential steps to help prevent tire blooming. For the best results, it’s recommended to do both.
Cleaning Tires
For regular cleaning as a preventative measure against blooming, follow these steps:
Use Quality Tire Dressings
Tire dressing is the most common and popular form of protection when tire sidewalls turn brown. Quality tire dressing offers the following benefits:
Dressings fill the tiny pores on the tire surface, enhancing the tire’s color depth. There are three types of finishes that can be achieved: glossy, satin, and matte. However, the effect is not long-lasting, and tire sidewalls may turn brown again over time. This is due to the liquid ingredients and the thin layer of application. If the tires are perfectly clean, you can apply two or more layers for a more long-lasting effect.
Avoid silicone-based products! They can draw dirt and potentially degrade the tire’s appearance by accumulating grime.
Tire Wax
Tire waxes lubricate the tire and fill the pores with essential components. Although their composition is different, tire waxes act similarly to shoe waxes. However, tire wax requires more time to apply because the tire must be cleaned and degreased beforehand. After applying the wax, you need to wait and then buff it off.
Tire Sealant
Sealants are the least common type of tire coating, but they are becoming increasingly popular due to their long-lasting effect.
Impact of Mold
Brake Dust Impact
Cleaning Tires
- Dry-Clean: Use a brush to remove most of the dirt and debris from the tires and rims.
- Rinse: Rinse the tires with water, preferably using a garden hose.
- Apply Cleaner: Use a special tire cleaner or make your own by adding one teaspoon of dish soap per gallon of water. Apply the cleaner and leave it for a couple of minutes or as specified in the cleaner’s manual.
- Scrub: Take a tire brush and clean every inch of the area where the tire sidewalls turn brown. Gradually move to the rest of the tire. Ensure the brush isn’t too harsh to avoid scratching the tire. Avoid brushes with steel teeth, as they may penetrate the rubber and cause air leaks.
- Rinse again: Use a pressure washer or garden hose to rinse the wheels and tires, washing off as much dirt as possible. Tire cleaners are usually environmentally friendly, so you can let them flow into the yard with the water.
- Repeat: Repeat the process if necessary.
- Dry: Dry the tires and rims with a towel.
- Intensifies the rubber’s black color
- Safeguards against subsequent discoloration and blooming
- Restores the black appearance
- Offers a protective layer against UV rays and dirt
- Seals and conditions the tires
- Water-based
- These usually look like a milky liquid and contain a combination of natural oils and synthetic polymers. Many water-based coats also have special UV-protecting elements and don’t cause rubber degradation over time. Additionally, this type is the most environmentally friendly and economical.
- Solvent-based
- These usually have silicone as their base and look like a sticky, clear liquid. They are more concentrated and create a glossy film on the tire when applied. However, solvent-based dressings may contain petroleum distillate solvents that can cause premature rubber deterioration.
Tire Wax
Tire Sealant
